I think I figured out something Panos is doing with the Taskbar
That Fool Pool Man
Hiya,
Okay. So. I wasn't pleased that on my 1080p 14 inch Lenovo that the Win11 taskbar icons are... bigger. And that there's no 'smaller' option which I and zillion people in the Feedback Hub agree is necessary. Others are FURIOUS that you can't move the taskbar to the top or to the left.
When you look at all those complaints at the same time... do you see what Windows is trying to manipulate into doing?
If you don't like the look of the big sized taskbar -- turn 'automatically hide taskbar' on.
The result?
1. You gain more vertical height -- which on almost all screens is desperately needed.
2. If you need the taskbar it's still the same move to get to it and click something (albeit it takes half a second longer)
3. If you hit the Windows key you get the taskbar, the start menu, the time, and all that other OS clutter back for a moment
4. There's no longer an argument for a top or left or rightee taskbar -- since -- you don't really see it anyway
I'm no Windows apologist. But I think this is an intentional design move. Give it a try if you don't believe me. It erases clutter. Do it for a few days and then look at how 'obtrusive' the Mac dock seems in comparison.
Doe you really need these Hasbro apps staring you in the face all day?
I guess it is a matter of the way the computer is used?
I have my shortcuts on the taskbar (Only eight). I prefer that to cluttering my much used dektop, where any shortcuts will be hidden by whatever you may be doing.
The Start menu is always there to save that problem, but that is another click away
And, fwiw, my icons on the taskbar are considerably smaller than yours - keeping in mind, the taskbar can be hidden.
