All-In-One (AIO) Runtimes 19.07.24 Silent Edition (x86/x64)
All-In-One (AIO) Runtimes 19.07.24 Silent Edition (x86/x64)​
1722088721412.png​
RuntimePack is a free runtime component assembly installer. The software was created and developed by the Russian developer JamesZero. RuntimePack can be downloaded from any other trusted website. RuntimePack adds runtime libraries to Windows and includes the libraries and components recommended for Windows installation. RuntimePack has most of the runtime libraries needed, making it simpler and easier to install. Unlike its alternatives, Delphi Runtime and Visual C++, with this app, you don't have to install many individual components.
All In One Runtime Pack
RuntimePack takes away the hassle of having to figure out which Microsoft Visual C++ Redistributable packages are needed. RuntimePack includes most of the DLL and OCX files required that might be missing or unregistered which causes system errors. It also consists of both x64 and x86 versions, so it works on all Windows PCs.
Why Would One Need RuntimePack?
When installing Windows, the runtime library is the library file needed by a program when it runs, provided by the Dynamic-link library. These libraries have various functions in programming and are a practical way to install the sharing function libraries in Windows. The file extensions for these libraries are *.dll, *.drv, and *.ocx. RuntimePack has all these functions in one place, saving you the time of having to install each one of them. When you install an application or a portable version of the software, and if it doesn’t start up or receive an error message, you can use RuntimePack. An example of an error message is 'xxx.dll file is missing; xxx has stopped working'. This error indicates that a dynamic-link library file is missing or cannot be found. When this error occurs, you can install RuntimePack. It may not solve all the problems, but it will fix most of them. Apps like RuntimePack are now a necessary tool needed to perform maintenance on your PC.
Detect System Architects
When you have RuntimePack running on your PC, it has DLL and VC++ runtime libraries that detect system architects (32-bit or 64-bit). This way, you can install the installation according to the corresponding runtime package. RuntimePack is produced and packaged based on the RTM version of VC++ runtime libraries released by Microsoft. Among all the runtime library installation packages (that’s considered all-in-one packages), RuntimePack is one of the best.
Contents (Updated till July 2024)
  • NET Desktop Runtime (8.0.7)​
  • Java SE Runtime Environment (JRE) (8.0 Update 421) [REMOVABLE By USER]​
  • Microsoft Edge WebView2 Runtime 126.0.2592 [REMOVABLE By USER]​
  • DirectX End-User Runtimes (9.29.1974)​
  • Microsoft Visual Basic/C++ Runtime x86 (1.1.0)​
  • Microsoft Visual C++ Redistributable 2005 x86 (8.0.61187)​
  • Microsoft Visual C++ Redistributable 2005 x64 (8.0.61186)​
  • Microsoft Visual C++ Redistributable 2008 x86 – x86 (9.0.30729.7523)​
  • Microsoft Visual C++ Redistributable 2010 x86 – x64 (10.0.40219)​
  • Microsoft Visual C++ Redistributable 2012 x86 – x64 Minimum Runtime (11.0.61135)​
  • Microsoft Visual C++ Redistributable 2012 x86 – x64 Additional Runtime (11.0.61135)​
  • Microsoft Visual C++ Redistributable 2013 x86 – x64 Minimum Runtime (12.0.40664)​
  • Microsoft Visual C++ Redistributable 2013 x86 – x64 Additional Runtime (12.0.40664)​
  • Microsoft Visual C++ Redistributable 2015-2022 x86 – x64 Minimum Runtime (14.40.33810) [REMOVABLE By USER]​
  • Microsoft Visual C++ Redistributable 2015-2022 x86 – x64 Additional Runtime (14.40.33810) [REMOVABLE By USER]​
  • Microsoft Visual Studio 2010 Tools for Office Runtime x86 - x64 (10.0.60917)​
  • Microsoft XNA Framework Redistributable 4.0 Refresh​
  • NVIDIA PhysX 9.21.0713 [REMOVABLE By USER]​
  • MSXML 4.0 [REMOVABLE By USER]​
  • OpenAL 1.1 [REMOVABLE By USER]​
  • Visual F# 4.1 SDK [REMOVABLE By USER]​
  • 7z SFX Builder v2.1 [REMOVABLE By USER]​
  • 7Zip 23.07 [REMOVABLE By USER]​
  • Adobe AIR 51.0.1.3 [REMOVABLE By USER]​
  • Resource Hacker 5.2.7 [REMOVABLE By USER]​
