Anyone with a blank widget screen? - The fix
CymruUSA
If you come across this where your widgets are failing to display and just leaves a grey layer, the fix is very easy and if you follow these instructions, the fix is instant.
Go to>Device Manager>Display Adapters and expand it. Right click on your display adapter and go to Properties>Driver and click disable device. Confirm yes. Your screen may go blank for a second but when it comes back up, your widgets will now display.
Hope it helps someone.
Sepi
it work, but you should enabel it again, ans some of the laptop may be need to force shuting down/ restart.
Salamcont
Thank you very much. Worked fine
