ASRock Z790-PRO-RS
Bill Shannon
I have a ASRock MB Z790 Pro Rs and recentlythe harddrives started dropping out and I found the power wire to the fan on the gigabyte n14180 card (gv-r477ud-1gi) was broken fixed it but card still produced an error soI replaced the card with a card that didn't require the power supply connected to run fans. It runs great now but is very slow to bood to graphics card and bios choices then from there its a bit quicker to windows 11 does anyone know of a grapgics card that would be faster loading without the requirement for external power from power supply?
Solution
I have fixed firefox crashing only took 3 years and 3 weeks. The add ons and auto config I turned off and changed and add blocker was a bad culprit. 2 motherboards 20 harddrives 3 power supplies 2 dvd burners and one sata mobile rack later my computer is running fine.
Three years and three weeks, two motherboards, twenty hard drives, three power supplies, two optical drives, and a SATA bay! That is the ultimate trial by fire for troubleshooting.
There is nothing quite as frustrating (or exhausting) as replacing physical hardware over and over, only to discover a rogue Firefox add-on and an overly aggressive ad blocker were pulling the strings in the background the entire time. Ad blockers in particular can wreak absolute havoc—when...
Bill Shannon
Found I/o Error in a HDD had to remove two and replace them computer is working well now and I have formatted the offensive drives and now they seem to work ok no errors in the mobile rack (sata) any opinions as to the i/o errors could have been fixed by simple format or will they fall over again should I try to use them. They are segate drives I got seagate as 20 years ago they were the best now they seem like the worst I have 6HDD's in my puter they were all segate at the start now I only have one seagate left in my computer.
Bill Shannon
B1 Initalizelibrary failed - this I have found tonight is in the Bios the Advanced / security or protection / has a number of protections for your computer eg anything not microsoft basicly except for edge as their sharing code with google and firefox. This some how being turned on has done damage to my files I have been using for 24 years in my spreadsheets I use for household manangment. It's NOT a RUNTIME error so don't mess with your runtime like I did the next firefox browser update should fix my issues with firefox that is left from incorrect switches being turned on in the bios. For me this is 75% cured now and I got a new notebook out of it as I needed a realiable computer for mananging NDIS for my disabled partner. Alsi few days ago i turned on 256 switches and that helped also.
Bill Shannon
My PSU was also upgraded from 500w to 750w and seems to not struggle as much as before. So elec bill will increase a bit.
Bill Shannon
If anyone Has a ASrock motherboard crashing their not plug and play compatable autodriverinstaller(v2.0.0.6) is needed for a ASROCK z790-pro-rs from the asRapp shop.
Device name
Processor 13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz
Installed RAM 64.0 GB (63.8 GB usable)
Device ID BC98C705-94DE-45B6-9B43-D6A374085D75
Product ID 00330-80000-00000-AA621
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Pro
Version 24H2
Installed on ‎12/‎11/‎2024
OS build 26100.3323
Experience Windows Feature Experience Pack 1000.26100.54.0
NVIDIA Geforce GTX 960 graphics card.
Bill Shannon
Yes, the 13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz processor does feature integrated graphics, specifically the Intel UHD Graphics 770
Bill Shannon
Does your CPU support integrated graphics?
The NVIDIA GeForce GTX 960, a dedicated graphics card, significantly outperforms the Intel UHD Graphics 770, an integrated graphics card, in terms of gaming performance and overall graphics capabilities.
Here's a more detailed comparison:
  • GeForce GTX 960:
    • A dedicated graphics card launched in 2015.
  • Offers significantly higher performance for gaming and demanding tasks.
  • Can handle 1080p gaming at high settings and even some 1440p gaming with reduced settings.
  • Supports features like NVIDIA Surround for immersive gaming experiences.
  • Intel UHD Graphics 770:
    • An integrated graphics card (IGP) found in Alder Lake and Raptor Lake SoCs.
  • Offers basic graphics capabilities for everyday tasks and light gaming.
  • Performance depends on the CPU model it is integrated in and the used memory.
  • While it can handle basic tasks and some older games, it's not suitable for modern, graphically demanding games.
  • In benchmarks, the UHD 770 at stock settings showed a GPU score similar to a Vega 6 with DDR4-3200.
  • Overclocking can increase performance by around 47%.
In essence: If you're looking for a graphics card for gaming, the GTX 960 is a much better choice than the Intel UHD Graphics 770. The GTX 960 offers a substantial performance boost for gaming and other graphics-intensive tasks.
Bill Shannon
Bill Shannon
I have just found Copilot running in the background is the virus that has been effecting my facebook market place and open office files even though you turn it off in start up in settings / apps/ installed apps you will find another switch to switch copilot off from running in the background this is very sneaky. I have been chasing this problem for over a year even the computer guys couldn't find this as they would have thought copilot wasn't running as it was not set to run at start up but was set to run in the background via a separate setting.
Just download Chameleon StartUp Manager (trial version) and disable / remove Co-Pilot from there from auto starting up ..
Bill Shannon
Yes I have integrated graphics however because of Microsoft BS, windows will only load it's permitted drivers and not unverified drivers so all I have driving my integrated GPU is plain Microsoft drivers this is so pathetic just an example of Microsoft wanting to dominate hardware well this was my first and last computer I'll make run by intel products you know the CPU alone cost 1,000 and a new graphics card will cost $1,700.00 if I opt to fix this issue when drivers for my current graphics card would suffice. The guy that sold me the Motherboard as an AMD board knew what he was doing to get rid of it.
Bill Shannon
  • I had a number of problems.
  • The ASROCK Z790 Pro rs did not get along with the two solid state drives that were fitted one after the other so now I'm running A HDD a good model seagate 1tb for the c Drive.
  • Then I found the companies like Facebook, yahoo, marketplace, and heaps more have code to freeze your computer if you run and add blocker as it interferes with their profits i assume.
  • the other Issue which was so difficult to diagnose was the Master Tower Case whilst it looked really nice so nice infact I purchased two of the cases both giving the same problem and that issue is the front two USB ports on the front of the computer don't function properly and keep switching on and off and causing sd cards to malfunction and require reformatting
  • I also put in anew power supply with an on off switch 800kw..
  • this has taken over 2 years to iron out these bugs and faults the usb ports on the front I just won't use I have 4 in one adaptors that I can use so all good I am so happy this computer works the way it should now.
  • I also disabled a lot of AI stuff as AI is so useless as words have no definite definition like numbers in a calculator do AI will never work. Eg I AI searched Linda Still - missing and got Linda - still missing it will never work.
Bill Shannon
There is nothing quite as frustrating (or exhausting) as replacing physical hardware over and over, only to discover a rogue Firefox add-on and an overly aggressive ad blocker were pulling the strings in the background the entire time. Ad blockers in particular can wreak absolute havoc—when they block a script or media pipeline, they can cause the browser process to stall out, spike memory, or hang the entire display driver, making it feel 100% like a failing motherboard, power supply, or drive controller.
I trusted firefox to ensure add ons were functional with the browser. I also changed fromVGA to hdmi lead, activated PCIe in bios but couldn't get the gpu to run through back socket on MB. Not experiencing conflict between usb_c and GPU thanks to a recent microsoft upgrade KB5121767. It helped a little. None of the firefox updates were directed at these issues. so now my 13900 i7 and ddr5 ram and 1700mb is practily out of date this has been a huge learning curve none of the IT guys I took my computer too could fix this problem the weird thind none of my asus notebooks were effected by these bugs.
I also changed the graphics card to a geforce gtx750 didn't do much but thought I should also mention this.
Solution
