Hi! here are a few more tips. Ensure your Wi-Fi adapter drivers are up to date; you can usually find these on the manufacturer's website. If you are using a laptop, go to your Device Manager, find your Wi-Fi adapter, and check the Power Management tab. Make sure the setting that allows the computer to turn off the device to save power is unchecked. Sometimes resetting your network adapter can help. Open a command prompt and type ipconfig /release followed by ipconfig /renew.
Keep in mind that temporary issues with your internet service provider can also cause disconnections, so if the issue persists, it might be worth giving them a call. Good luck!
