modeltrice
- Aug 5, 2024
I set up my iPhone with Phone Link, and everything worked fine. I could make and receive calls using my wired headset. However, after removing and re-adding my iPhone to Phone Link, I can see call notifications, but there's no sound, and I can't select the PC as an audio option on my iPhone during calls.
I tested with another iPhone, and it worked perfectly the first time, but the same issue occurred after I removed and re-added it. Once the phone is removed and reconnected, I can't make calls.
Is there a workaround for this?
Troubleshooting done:
I removed the phone from Phone Link
Removed the phone from Windows Bluetooth devices
Removed the Windows PC from iPhone Bluetooth devices
Restarted both PC and iPhone
Re-added the iPhone to Phone Link
