Change File Explorer right click?
alan sh
Is there a way to change what you see when you right click a file or folder? Most of what I do is in the 'more options' and I'd like to move them so I can get at them straight away. An example is 'Connect network drive'.
Cheers
Alan
I just used the file they provided that provides a method to perform the hack and a method to undo it if you choose to return the Windows 11 function.
As always, when fiddling with the registry, make sure you have manually created a system restore point in advance.
