It's not recommended to skip CHKDSK or CHKNTFS because it will cause more file folder corruption in future .. however;
Use the Registry Editor for doing a host of other things; and in this case, this means you can disable your disk checking through it as well. Here’s how you can get started.
- Head to the Start menu search bar, type in ‘registry editor,’ and select the best match.
- In the Registry Editor, expand the HKEY_LOCAL_MACHINE key and click on SYSTEM > CurrentControlSet > Control.
- From there, click on the Session Manager and double-click on BootExecute.
- Set the Value data in the following dialog box to autocheck autochk krive (where Drive is the drive you’re canceling the ) and click OK.
Disk checking will be disabled as soon as you complete the above steps. And, if you’d like to enable it again in the future, then all you’ve to do is type in autocheck autochk * in the value data exchange again, and everything will be back to normal.
