Hi All
I have new build pc which crashes, freezes randomly or every time i try to run " msdt.exe -id DeviceDiagnostic ". stop code is CLOCK WATCHDOG TIMEOUT. I have tried many fixes and windows repair tools to no avail. 20 years ago my pc knowledge was above amateur but now i have fallen behind so much this issue is beyond me, please help.
pc info :
Processor 12th Gen Intel(R) Core(TM) i5-12500, 3000 Mhz, 6 Core(s), 12 Logical Processor(s)
BaseBoard Product MAG B660M MORTAR WIFI DDR4 (MS-7D42)
BIOS Mode UEFI
System Type x64-based PC
ssd 500 GB
DDR4 RAM 32GB
Windows 11 Pro.
dump file info:
Microsoft (R) Windows Debugger Version 10.0.25136.1001 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\063022-4218-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22000 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 22000.1.amd64fre.co_release.210604-1628
Machine Name:
Kernel base = 0xfffff804`2ba00000 PsLoadedModuleList = 0xfffff804`2c6296b0
Debug session time: Thu Jun 30 05:42:52.235 2022 (UTC - 7:00)
System Uptime: 0 days 0:00:04.888
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff804`2be15590 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffc089`5b45f370=000000000000004c
3: kd> !analyze -v
* Bugcheck Analysis *
WINLOGON_FATAL_ERROR (c000021a)
The Winlogon process terminated unexpectedly.
Arguments:
Arg1: ffffaf043d5c2a50, String that identifies the problem.
Arg2: ffffffffc0000428, Error Code.
Arg3: ffffaf0439cffcf0
Arg4: 0000000000000000
Debugging Details:
ETW minidump data unavailable
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2265
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 2399
Key : Analysis.Init.CPU.mSec
Value: 202
Key : Analysis.Init.Elapsed.mSec
Value: 3032
Key : Analysis.Memory.CommitPeak.Mb
Value: 88
Key : Bugcheck.Code.DumpHeader
Value: 0xc000021a
Key : Bugcheck.Code.Register
Value: 0x4c
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
FILE_IN_CAB: 063022-4218-01.dmp
ERROR_CODE: (NTSTATUS) 0xc000021a - {Fatal System Error} The %hs system process terminated unexpectedly with a status of 0x
EXCEPTION_CODE_STR: c000021a
EXCEPTION_PARAMETER1: ffffaf043d5c2a50
EXCEPTION_PARAMETER2: ffffffffc0000428
EXCEPTION_PARAMETER3: ffffaf0439cffcf0
EXCEPTION_PARAMETER4: 0
BUGCHECK_CODE: c000021a
BUGCHECK_P1: ffffaf043d5c2a50
BUGCHECK_P2: ffffffffc0000428
BUGCHECK_P3: ffffaf0439cffcf0
BUGCHECK_P4: 0
PROCESS_NAME: smss.exe
ADDITIONAL_DEBUG_TEXT: Verification of a KnownDLL failed.
IMAGE_NAME: ntkrnlmp.exe
MODULE_NAME: nt
BLACKBOXNTFS: 1 (!blackboxntfs)
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffffc089`5b45f368 fffff804`2c46831f : 00000000`0000004c 00000000`c000021a ffffc089`5b52a318 ffff8684`d89c7190 : nt!KeBugCheckEx
ffffc089`5b45f370 fffff804`2c459344 : 00000000`00000000 ffffc089`5b45f430 ffffffff`800002b0 00000000`00000000 : nt!PopGracefulShutdown+0x2af
ffffc089`5b45f3b0 fffff804`2c44f82c : 00000000`00000001 ffffaf04`00000006 00000000`00000000 00000000`00000005 : nt!PopTransitionSystemPowerStateEx+0x12e5c
ffffc089`5b45f470 fffff804`2be27b75 : fffff804`2ba10a78 fffff804`2bcff249 00000000`00000000 fffff804`29924c80 : nt!NtSetSystemPowerState+0x4c
ffffc089`5b45f640 fffff804`2be19de0 : fffff804`2c2c9c20 00000000`00000014 ffffffff`ffffff00 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
ffffc089`5b45f7d8 fffff804`2c2c9c20 : 00000000`00000014 ffffffff`ffffff00 00000000`00000000 fffff804`2c622fe0 : nt!KiServiceLinkage
ffffc089`5b45f7e0 fffff804`2c1e7be0 : ffffde80`2769f180 00000000`00000080 ffff8684`d857d040 fffff804`2bd1d679 : nt!PopIssueActionRequest+0xe1c78
ffffc089`5b45f880 fffff804`2bc467a9 : 00000000`00000001 00000000`00000000 ffffffff`ffffffff fffff804`2c733680 : nt!PopPolicyWorkerAction+0x80
ffffc089`5b45f900 fffff804`2bd1d04f : ffff8684`00000001 ffff8684`d857d040 fffff804`2c622f40 ffff8684`00000000 : nt!PopPolicyWorkerThread+0xa9
ffffc089`5b45f940 fffff804`2bc478f5 : ffff8684`d857d040 ffffde80`273d0000 ffff8684`d857d040 004fe47f`bd9bbfff : nt!ExpWorkerThread+0x14f
ffffc089`5b45fb30 fffff804`2be19644 : ffffde80`273c1180 ffff8684`d857d040 fffff804`2bc478a0 00000000`00000000 : nt!PspSystemThreadStartup+0x55
ffffc089`5b45fb80 00000000`00000000 : ffffc089`5b460000 ffffc089`5b459000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME: nt!PopTransitionSystemPowerStateEx+12e5c
IMAGE_VERSION: 10.0.22000.318
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 12e5c
FAILURE_BUCKET_ID: 0xc000021a_SmpInitializeKnownDlls_c0000428_BAD_DLL_difxapi.dll_nt!PopTransitionSystemPowerStateEx
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {299089e9-f138-4840-956f-7abf42a0d528}
Followup: MachineOwner
pc info :
BIOS Mode UEFI
ssd 500 GB
DDR4 RAM 32GB
Windows 11 Pro.
dump file info:
Deferred srv*
Machine Name:
nt!KeBugCheckEx:
3: kd> !analyze -v
Arguments:
Debugging Details:
Value: 2265
Value: Create
Value: 2399
Value: 202
Value: 3032
Value: 88
Value: 0xc000021a
Value: 0x4c
Key : WER.OS.Branch
Value: co_release
Value: 10.0.22000.1
BUGCHECK_P4: 0
MODULE_NAME: nt
STACK_TEXT:
OSNAME: Windows 10
