CPU Temperature Shows at 0 Degrees After Core Unlocking
sobredosise3
Hi there,
I've noticed that my BIOS does not show my CPU temperature correctly after I tweaked the cores using the system configuration. Although I reverted the changes to their original settings, the issue persists. In BIOS, my CPU temperature is consistently displayed as 0 degrees Celsius.
Is there a way to fix this?
My CPU is AMD Ryzen 9 3900, 12 cores.
Thank you
