Dll WIL error
Unfortunately, this is a bug that occurred due to the association of the online account with your windows, which has already been reported to several users, usually deactivating the microsoft account login service, but this disables the entire system to connect to the online system with the Microsoft store and other apps from windows.
You can try to run the command in powershell (admin): Install-Module MSOnline -Force
Restarting the computer to see if that solves it or resetting the error log in the event viewer so that it stops reporting. It has already been reported to Microsoft about the problem occurred in Feedback Hub.
Erinadams
Thank you for answering me. I also found a solution to this problem last night. If you or anyone else has the same problem, you can take a look at this.
RasulGreen
Hey @Erinadams
As @Xploit Machine mentioned, this issue is related to the Microsoft account association with Windows. He suggested disabling the Microsoft account login service (which may affect Microsoft Store and other apps) and running the following PowerShell command:
powershell
CopyEdit
After running it, restart your PC and check if the error is gone.
You can also try these additional steps:
  1. Run System File Checker (SFC): Open Command Prompt (Admin) and run:
    bash
    CopyEdit
    sfc /scannow
    Restart your PC after it finishes.
  2. Check Event Viewer: Open Event Viewer (eventvwr.msc), go to Windows Logs > Application/System, and look for details on the error.
  3. Create a New Local User Account: If the issue is tied to your account, creating a new user profile might help.
  4. Update Windows & Drivers: Make sure your system is fully updated via Windows Update and Device Manager.
  5. Rollback or Reset Windows (if needed): If the issue started after an update, try rolling it back or resetting Windows as a last resort.
Since this has already been reported to Microsoft, they may release a fix in a future update.
