DPC Watchdog Violation
AJH748
I keep getting this BSOD on my Windows 11 machine.
I think this is the correct dump file.
Can anyone advise what I needs to do now please.
************* Preparing the environment for Debugger Extensions Gallery repositories **************
ExtensionRepository : Implicit
UseExperimentalFeatureForNugetShare : true
AllowNugetExeUpdate : true
AllowNugetMSCredentialProviderInstall : true
AllowParallelInitializationOfLocalRepositories : true
-- Configuring repositories
----> Repository : LocalInstalled, Enabled: true
----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.234 seconds
----> Repository : UserExtensions, Enabled: true, Packages count: 0
----> Repository : LocalInstalled, Enabled: true, Packages count: 36
Microsoft (R) Windows Debugger Version 10.0.25921.1001 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\alanh\AppData\Local\Microsoft\Edge\User Data\Crashpad\reports\3da5fd1e-0cd8-40f1-990a-09bd613967c7.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Version 22621 MP (12 procs) Free x64
Product: WinNt, suite: SingleUserTS Personal
Edition build lab: 22621.1.amd64fre.ni_release.220506-1250
Debug session time: Mon Mar 4 11:46:02.000 2024 (UTC + 0:00)
System Uptime: 12 days 23:24:03.108
Process Uptime: 4 days 20:05:13.000
Loading unloaded module list
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(917c.ade8): Unknown exception - code 0517a7ed (first/second chance not available)
| This target supports Hardware-enforced Stack Protection. A HW based |
| "Shadow Stack" may be available to assist in debugging and analysis. |
| See aka.ms/userhsp for more info. |
| dps @ssp |
For analysis of this file, run !analyze -v
ntdll!NtWaitForSingleObject+0x14:
00007ffd`6a68f3f4 c3 ret
* Exception Analysis *
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 577
Key : Analysis.Elapsed.mSec
Value: 20044
Key : Analysis.IO.Other.Mb
Value: 56
Key : Analysis.IO.Read.Mb
Value: 135
Key : Analysis.IO.Write.Mb
Value: 305
Key : Analysis.Init.CPU.mSec
Value: 484
Key : Analysis.Init.Elapsed.mSec
Value: 1010158
Key : Analysis.Memory.CommitPeak.Mb
Value: 247
Key : Failure.Bucket
Value: APPLICATION_FAULT_517a7ed_msedge_elf.dll!crash_reporter::DumpWithoutCrashing
Key : Failure.Hash
Value: {6d8d74dd-b055-2a68-3b16-135f8b24a2d2}
Key : Timeline.OS.Boot.DeltaSec
Value: 1121043
Key : Timeline.Process.Start.DeltaSec
Value: 417913
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Version
Value: 10.0.22621.1
Key : WER.Process.Version
Value: 122.0.2365.52
FILE_IN_CAB: 3da5fd1e-0cd8-40f1-990a-09bd613967c7.dmp
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
APPLICATION_VERIFIER_FLAGS: 0
CONTEXT: (.ecxr)
rax=0000008c8b9fd750 rbx=aaaaaaaaaaaaaaaa rcx=0000008c8b9fd750
rdx=00000000000000ba rsi=0000008c8b9fd750 rdi=0000000000000000
rip=00007ffd28db5a57 rsp=0000008c8b9fd730 rbp=000077f000221500
r8=00000000000000c0 r9=00000000000000c0 r10=00007ffd28ad0000
r11=00007ffd28ccd71b r12=0000008c8b9fdca0 r13=0000008c8b9fdcb0
r14=aaaaaaaaaaaaaaaa r15=0000008c8b9fdd30
iopl=0 nv up ei pl nz na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000206
msedge_elf!crash_reporter::DumpWithoutCrashing+0x37:
00007ffd`28db5a57 4889f1 mov rcx,rsi
Resetting default scope
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 00007ffd28db5a57 (msedge_elf!crash_reporter::DumpWithoutCrashing+0x0000000000000037)
ExceptionCode: 0517a7ed
ExceptionFlags: 00000000
NumberParameters: 0
PROCESS_NAME: msedge.exe
ERROR_CODE: (NTSTATUS) 0x517a7ed - <Unable to get error code text>
EXCEPTION_CODE_STR: 517a7ed
STACK_TEXT:
0000008c`8b9fd730 00000000`00000000 : 00000a32`2186cb8b 00005cb6`7ea944f6 0000008c`8b9fd788 00000000`00000000 : msedge_elf!crash_reporter::DumpWithoutCrashing+0x37
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_NAME: msedge_elf!crash_reporter::DumpWithoutCrashing+37
MODULE_NAME: msedge_elf
IMAGE_NAME: msedge_elf.dll
FAILURE_BUCKET_ID: APPLICATION_FAULT_517a7ed_msedge_elf.dll!crash_reporter::DumpWithoutCrashing
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 122.0.2365.52
FAILURE_ID_HASH: {6d8d74dd-b055-2a68-3b16-135f8b24a2d2}
Followup: MachineOwner
Many thanks
