Drop down box addition?
Phoenix
I freqeuntly use Optimize (defragment)
but do not like leaving the process
for Windows to decide when to do it.
What I would like to do is plce the option
to run the utility from the helpful
right-click drop-down box that pops up in
explorer and other places.
Is this possible?
If so, how?
Any assistance apprecited.
ToolGuy
Yes, it is possible to add the Optimize (defragment) option to the right-click context menu in Windows. Here's how:
  1. Open File Explorer and navigate to the C:\Windows\System32 folder.
  2. Scroll down and locate the "defrag.exe" file.
  3. Right-click on "defrag.exe" and select "Create shortcut".
  4. A prompt will appear asking if you want to place the shortcut on the desktop. Click "Yes" to create the shortcut.
  5. Move the shortcut to a location of your choice, such as the desktop or a folder.
  6. Right-click on the shortcut and select "Properties".
  7. In the "Target" field, add the following command line option at the end of the path: " /c /h".
  8. Click "Apply" and then "OK" to save the changes.
The shortcut is now configured to run the Optimize (defragment) utility. To add the shortcut to the right-click context menu, follow these steps:
  1. Open the Registry Editor by pressing the Windows key + R, typing "regedit" and pressing Enter.
  2. Navigate to the following registry key: HKEY_CLASSES_ROOT\Drive\shell
  3. Right-click on the "shell" key and select "New" -> "Key".
  4. Name the new key "Defrag".
  5. Right-click on the "Defrag" key and select "New" -> "Key".
  6. Name the new key "command".
  7. Double-click on the "(Default)" value in the right pane.
  8. In the "Value data" field, enter the path to the defrag.exe shortcut, including the "/c /h" command line option.
  9. Click "OK" to save the changes.
The Optimize (defragment) option should now appear in the right-click context menu when you right-click on a drive in File Explorer. Note that making changes to the registry can be risky, so it's a good idea to back up the registry before making any changes.
Phoenix
Thanks.
Will try it.
Tried.
Got to the point of naming new key Defrag.
Next step, when naming the command, I double-clicked on the "(Default)" value in the right pane.
In the "Value data" field, entered the path to the defrag.exe shortcut,
which was ddfgui.exe
as
%windir%\system32\dfrgui.exe /c /h
Clicked "OK" to save the changes
The option of Defrag does indeed show up in the context menu, yet
a window pops up on activation stating there is no application associated.
I am sure this is operator error....
Guidance?
Phoenix
In the "Value data" field, I entered the path to the defrag.exe shortcut, including the "/c /h" command line option
by typing
%windir%\system32\defrag.exe /c /h
Should I have instead just used
defrag /c /h ?
Hmph. That did not work either.
Same error message popped up.
ToolGuy
by typing
defrag /c /h ?
If you prefer to use the command "defrag /c /h" instead of the path to the defrag.exe shortcut, you can certainly do so. However, make sure that you enclose the command in quotes and add a space before the "/c /h" option, like this:
"defrag" /c /h
If you tried this and it didn't work, it's possible that there may be an issue with your registry settings or the permissions for the current user.
Phoenix
"defrag" /c /h
Simple question from a simple mind...
Changes to registry require restart of pc before taking effect, yes?
Rebooted pc.
In the command key I have "defrag" /c /h
Not working
Did this while in administrator account.
Wondering if I must specify in there the complete path to defrag, as in
"C:\Windows\System32\defrag" /c /h
