It's still pretty early to tell, which particular software products work well with Windows 11 and which ones do not.
It's likely spawned by the Task Scheduler so, you may want to locate it and disable it or delete it until such time as Intel provides and updated version.
Also check the startup tab in Task Manager to see if it is also there. IF so, disable there as well.
