The post from Bighorn may be correct, I don't have experience trying to uninstall Edge. The website listed below states that you can remove Edge and provides instructions including a caveat that there may be issues afterwards. Personally, I would leave Edge as installed and just not use it.How can i remove edge browser, completelly without a trace?
ThanksThe post from Bighorn may be correct, I don't have experience trying to uninstall Edge. The website listed below states that you can remove Edge and provides instructions including a caveat that there may be issues afterwards. Personally, I would leave Edge as installed and just not use it.
How to Uninstall Microsoft Edge from Windows 11 | TechRepublic
This tutorial guide shows you how to uninstall Microsoft Edge from Windows 11 using an unconventional method.www.techrepublic.com
ThanksI agree with the previous posters, if you remove it, you will very likely have system problems afterwards, at least in the long run.
But you can use MS Edge Redirect, which works nicely for me : https://github.com/rcmaehl/MSEdgeRedirect
(The problem with removing all the Edge startup entries which come back with every Edge update does however remain; I am using Autoruns to remove the entries).
