ExplorerPatcher 22621.2283.57.2
ExplorerPatcher is a versatile and free tool that allows you to tweak and enhance the Windows Explorer. It comes with a range of useful features, including the ability to add new context menu items, change file name colors, and enable hidden features.
Feature summary
  • Choose between Windows 11 or Windows 10 taskbar (with labels support, small icons and lots of customization).​
  • Disable Windows 11 context menu and command bar in File Explorer and more.​
  • Open Start to All apps by default, choose number of frequent apps to show, display on active monitor and more.​
  • Choose between the Windows 11, Windows 10 and Windows NT Alt-Tab window switcher with customization.​
Lots of quality of life improvements for the shell, like:
  • Skin tray menus to match Windows style, make them behave like flyouts and center them relative to the icon.​
  • Choose action when left and/or right clicking the network icon.​
  • Revert to the Windows 7 search box in File Explorer, or disable Windows Search altogether.​
  • Disable immersive menus and use mitigations that help you run the real classic theme without glitches.​
Download: ExplorerPatcher 22621.2283.57.2 | 1.8 MB (Open Source)
ExplorerPatcher 22621.2283.57.2 changelog:
Tested on OS build 22621.2283. Installer requires Internet connectivity.
  • Taskbar10: Fixed Action Center, Control Center, and notification toasts placements on OS builds 22621.2134+ (thanks @Amrsatrio).​
  • Taskbar10: Fixed a bug that prevented Task View and/or the window switcher (Alt+Tab) from working on OS builds 22621.2134+ (thanks @Amrsatrio).​
  • Taskbar10: Fixed a bug that prevented the volume and brightness flyouts from displaying (thanks @Amrsatrio).​
  • Taskbar10: Fixed a bug that prevented the Win+A (Action Center), Win+N (Control Center), and Win+B (Focus on tray overflow button) shortcuts from working on OS builds 22621.2134+ (thanks @Amrsatrio).​
  • Taskbar10: Fixed the context menu of the new IME button OS builds 22621.2134+ (thanks @Amrsatrio).​
  • Taskbar11: Fixed a bug that crashed explorer.exe when right clicking the taskbar on OS builds 22621.2134+.​
  • Quality of life improvements regarding symbol data (thanks @Amrsatrio).​
  • Fixed a bug that crashed explorer.exe on OS builds lower than 22621 (Windows 11 22H2).​
Please consult the README for more details and a detailed change log is available here.
