Fix Caps Lock Turning Off with Shift Key on Windows 11
Article Discussion Fix Caps Lock Turning Off with Shift Key on Windows 11
Windows Daily
Windows Daily submitted a new resource:
Fix Caps Lock Turning Off with Shift Key on Windows 11 - Reconfiguring advanced key settings does the trick in most cases.
If you're experiencing issues with the Caps Lock turning off when you press the Shift key on your Windows 11 device, here are some effective solutions to resolve the problem.
What can I do if Caps Lock turns off with the Shift key?​
1. Change Caps Lock Behavior via Advanced Keyboard Settings​
  • Open Settings:
    • Click on the Start Menu.
    • Select the gear icon to open the Settings app.
  • Navigate to Time...
Read more about this resource...
