Fix Get Help Not Working Issue on Windows 11/10 Quickly
Article Discussion Fix Get Help Not Working Issue on Windows 11/10 Quickly
Windows Daily
Windows Daily submitted a new resource:
Fix Get Help Not Working Issue on Windows 11/10 Quickly - A repair or reset is often effective in such cases.
If you're having trouble with the Get Help app on Windows 11 or 10, here are some solutions that can help you get it working again.
Fixing "Get Help App Not Working" in Windows 11/10?​
1. Restart Get Help​
  • Right-click the Windows logo button on the taskbar and select Task Manager.
  • In the Task Manager window, find and right-click the Get Help app from the list of running processes.
  • Select End task.
  • Re-open...
Read more about this resource...
