How to Fix 'Invalid Data Found When Processing Input' in Windows 11
Article Discussion How to Fix 'Invalid Data Found When Processing Input' in Windows 11
Windows Daily
Windows Daily submitted a new resource:
How to Fix 'Invalid Data Found When Processing Input' in Windows 11 - Keeping FFmpeg up to date will usually fix this error.
If you encounter the "Invalid data found when processing input" error while using FFmpeg on Windows 11, several solutions might help you resolve the issue. Here are detailed instructions to troubleshoot and potentially fix the problem.
How can I Fix "FFmpeg Invalid Data Found When Processing Input" Errors?​
1. Check File and Path​
  • Verify File Paths:
    • Ensure that the file paths provided to FFmpeg are correct.
    • Check for any...
Read more about this resource...
willomparker
The "Invalid Data Found When Processing Input" error in Windows 11 typically occurs when trying to open, play, or convert media files, often in Windows Media Player, VLC, or third-party software. It may also happen with system processes, like Windows Update or file transfers.
