How to preserve EMLX files with embedded images when converting to PDF?
jennyrozer
If you want to preserve EMLX files with embedded images when converting to PDF then you have to need a conversion tool. It can handle email content and embedded images in the converted PDF. You just simply load your EMLX file into the tool as the output format. This is a dedicated tool This tool Converts EMLX to PST, NSF, MBOX, EML, MSG, TGZ, MHTML & PDF, etc. If you are not technically smart, you can operate the tool. The conversion tool has interactive interfaces. DailySoft EMLX to PDF software gives users outstanding control over its key functions.
Avarozer
If you want to preserve EMLX files with embedded images when converting to PDF. Then you can use a third-party tool like the FixVare EMLX converter tool. This is an award-winning program to convert specific EMLX files to PDF. There is no need external solution to convert data, not even Adobe Acrobat. It can Convert data with all email attributes intact and remain unchanged. It Supports to export of one or many EMLX files to Personal Document Format at one time. This is the best tool
