I like using the "night sky" theme but I dont like the link borders on webpages and border colors on windows. I know there is an "edit" that allows limited customization, but is there a registry or further customization I can do?
While Windows 11 provides some limited customization options through the built-in settings, there are additional customization possibilities that can be explored through the Windows Registry. However, it's important to note that modifying the registry can have unintended consequences, and it's recommended to proceed with caution and create a backup of your registry before making any changes. Here's a general overview of how you can customize the appearance further:
By modifying these registry values, you can further customize the appearance of the "night sky" theme by adjusting the link borders on webpages and border colors on windows according to your preferences. Again, exercise caution when making changes in the registry, and if you're uncertain about any modification, it's best to seek guidance from expert resources or forums dedicated to Windows customization.
- Open the Registry Editor by pressing Windows key + R, then typing "regedit" and hitting Enter.
- Navigate to the following path in the registry: HKEY_CURRENT_USER\Control Panel\Colors
- In the right-hand pane, you'll find various color values that control different aspects of the Windows interface. For example, "Window" represents the border color of windows, and "Hypertext colors" control the colors of links in webpages.
- Double-click on a specific value to modify it. You can use hexadecimal color codes or predefined color names (e.g., "Red," "Green," etc.) to set the desired color.
- After making changes, close the Registry Editor and sign out or restart your computer for the changes to take effect.
