It might seem like a good idea to switch an Excel file to a vCard by manual method, but it can be quite difficult. It can be very difficult and lengthy to copy and paste data from Excel into a vCard file, especially if you have a lot of contacts. There is a chance you might make mistakes, which could lead to missing or incorrect contact details.
You could do this manually, but it would not be the fastest or most reliable way to do it. The manual approach lacks significant flexibility and is likely to make mistakes.
Instead, you might want to consider using a tool like the
DataVare Excel to vCard Converter. It’s an easy-to-use software that automates the entire conversion process. All you have to do is upload your Excel file; it will rapidly convert your contacts into the vCard format, saving you hours of work. It guarantees precise transfer of all your contacts and reduces the possibility of failures. This application can be simple installed on all Windows versions and supports all vCard file versions. If you want to try it out for free you can install its free trial edition from the official website.
