Microsoft Edge is managed by your organization
How do I turn this off? I'm a solo home user. I have never been organized.
Hello,
Firstly exit Microsoft Edge
1. Copy below code and put in Notepad then save it .. rename the file as <SOMETHING.REG> and then goto TASK MANAGER (press CTRL+SHIFT+ESC simultaneously)
2. At TASK MANAGER click top right saying RUN NEW TASK (this will popup RUN command box) tick the RUN AS ADMINISTRATOR / RUN WITH ADMINISTRATOR PRIVILEGES whichever applicable then click BROWSE, point to the file you have saved <SOMETHING.REG>) and run it
3. Accept everything by pressing OK
4. Restart WINDOWS EXPLORER or COMPUTER
The notification will be disabled Microsoft Edge Is Managed By Your Organization
.. or extract the ZIP file I have attached and run it in TASK MANAGER as RUN AS ADMINISTRATOR / RUN WITH ADMINISTRATOR PRIVILEGES
Windows Registry Editor Version 5.00
; Joe Isabella @ Xploit Machine
; 01 December 2022
; (e-mail address removed)
[-HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge]
[-HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Edge]
  • Remove Managed By Your Organization - EDGE.zip
The link below should solve the problem.
Scroll down the page to the section;
How to Remove Managed by your organization from Microsoft Edge​
