Only balanced power plan, how can I get the others?
james_uk
Hi, I have recently done a new installation of Windows 11.
I seem to only have balanced as a power plan option.
I have tried tutorials I found that show you how to add them via command prompt.
Oddly, this added balanced again as a second option, but it didn't add the other options.
Does anyone know how I can get them back?
Regards
James
Right click on START (Windows icon on taskbar) select RUN and type Control Panel -> OK
Goto Power Settings and Create Power Plan
As for me, I just use the existing Balanced Power, but changed the options and selections inside it rather than creating a new one :)
Regards
James
To reset Windows default power plans:
Open PowerShell with administrator rights.
In the PowerShell window, type the following command and press Enter:
powercfg -restoredefaultschemes
The above command will reset default power schemes. Close PowerShell and check for any improvements.
