OS2Go Pro does not work
kittensinurface
EaseUS OS2Go Pro creates custom Windows 11 stick, but it never boots, no matter if I download from MS server, or use my own ISO manually downloaded from MS web. Tried both 2TB NVMe external, 64GB stick. Does not boot on 2 PC UEFI-nonCSM x64. Does not boot automatically, or show up in UEFI temporary boot menu. Does not boot stick with MBR or GPT. Prior to creating stick with OS2Go Pro, I use Diskpart to clean disk, create partition table. How can I make this work? Thank you.
Well, don't keep doing the same thing and expecting different results.
STOP USING OS2Go!
To install Windows 11 all you need is two things: You'll need a clean ISO of Windows 11. You can download it from MS or other NON MS sources.
Then you need a copy of Rufus 4.0 or later. Use Rufus to burn the ISO to a Flash Drive of sufficient size.
And then use the Flash Drive to boot up your PC and install Win-11 to your HD.
It's really a very simple process, once you have the right stuff.
Good Luck,
kittensinurface
STOP USING OS2Go!
Good Luck,
Weak Troll
I've already installed Win-11 20+ times already, using the simple technique I outlined above.
You're the one having the problems, not me!
And you'll keep having problems, till you change your attitude.
