Quincofish
- Oct 6, 2021
Adding a user, Outlook 2007 just fails both encrypted and unencrypted.
Existing user was working fine, moved to new PC, tried to add user to Outlook 2007 on new PC, will not work. Would use the new outlook or the classic outlook, but can't import .pst folder from old PC (was using POP)
Also, on new laptop Win 11 with all current updates, file explorer does not have tabs and screen does not have the docking feature at the top.
Any clues how to fix these issues?
