PC no longer visible on local network
RicS
After installing Windows 11 on my laptop the laptop is no longer visible on my local network. Prevents me from moving files from my phone to PC. Anyone seen this behavior?
cj599
having a similar issue with a tve and wtching my movies on my pc worked before windows 11
cj599
try to find this in network i believe it worked with my issue
cj599
mine was set to public and i could not dtream my movies from my hard drive so i put it to private now it works
PA-WOODCHUCK
I have mine set to private and see the other home PC's , but asks for credentials to login window. I can't remember how to get around this?
thanks
cj599
try public thats what fixed mine i could see them but it would ask for credentials if i used my Microsoft user and password i could see them
cj599
i guess it makes your pc public only to the network your on not to outside people that aren't logged into your router
