JamesJoey123
- Nov 14, 2021
In the Task Manager>Startup apps, when I select the Phone Link item and check Properties, Windows tells
me it can't find 'PhoneExperienceHost.exe.'
Also, In the Task Manager>Startup apps, when I select Mobile Devices and check Properties, Windows tells
me it can't find 'CrossDeviceService.exe.'
How can I fix this?
Is there a way to check if I'm able to share my Windows PC and my Android tablet?
Thanks,
James
How can I fix this?
Thanks,
James
