Program That Compares Two Folders and Displays The Difference?
jdanniel
Hi everybody.
I’m looking for a freeware or shareware program that will compare the contents of two folders, and display the difference.
Let me elaborate.
Let’s say I have a folder named ALPHABET 1.
In the ALPHABET 1 folder, I have the following subfolders:
A B C X Y Z
I have a second folder, named ALPHABET 2.
In ALPHABET 2, I have the following subfolders:
A B C D E W X Y Z.
So, I’m looking for a program that will inspect these two folders, and will tell me the difference is:
D, E, W.
That's all I need it to do.
Does that make sense? Does anyone know of any programs that might do that?
Thank you!
J. Danniel
Hi everybody.
Let me elaborate.
A B C X Y Z
A B C D E W X Y Z.
D, E, W.
Thank you!
J. Danniel
I believe the app provided in the link below will do what you want.
jdanniel
Thank you for replying. This is PERFECT! Thank you.
But...if I may, I'd like to ask one question: How do you filter WinMerge so that it displays ONLY the different folders?
In the example below, I only want D, E, and W displayed. Is that possible? If so, what do I do to get this?
I'm SO close! Thank you so much.
Try total commander. It does the same way. I use it to sync my data drive with my backup drives.
I haven't used the app for awhile, but the link below has the settings for options and configuration. Maybe something can be changed that will ignore selected drives. I really don't know.
