I was using edge clicked on X upper right-hand corner screen went plain white. Nothing worked used the CTRL-control- delete keys to shut down. Then this error popped up in Window security file. Said this driver was incompatible driver version 3.1.1.0 . How do I fix this?
Resolving incompatible of this driver will enable you to turn on Memory integrity is the head of error statement. driver is Corel Corporation
