Running Surf Shark anti-virus
cyclist
Currently, I am running W11 Home 23H2. Has anyone used SS anti-virus that is built into their SS VPN? And if, so any conflicts with Windows Defender?
Shouldn't be a problem, if you have any option to disable the SS then you may because I'm afraid that will affect connection speed of the VPN :)
I have never used Surf Shark AV and can't offer personal experience. I use AV Comparatives to get information on what the best AV software is at the present time. Surf Shark does not appear on their list, so I would use one of the AVs tested by them. I have posted a link to their website for your review, if you are interested in checking their test results.
PS: To more directly answer your question, if you install another antivirus product, Microsoft Defender Antivirus automatically disables itself and is indicated as such in the Windows Security app.
this is the simple thing to do .. im my country there's no need VPN, can access anything around the globe ..for example (below video) .. I closed the tab because no X related post :D
I suggest you to take Freedome VPN .. no antivirus built-in ..
