Smart App Control
salado111
Hi! my 1st post... Windows 11 64bit - In Windows Security/App & Browser Control/ Mine is turned off? Can anyone shed some light on this pls. ? (It does say if it's off it can't be turned on without reinstalling windows?) ver. 23H2 (build 22631.4169) thank you
Solution
not a problem .. if you want it turn on then you need to fresh install W11, I dont bother because its not necessary :D
Solution
