Taskbar icons disappeared
jsmillo
Hey! does this happen to anyone else? My icons from the taskbar dissapear from time to time.... They make themselves visible once i click on them again.
This is a common issue on Windows 10 devices.
But you can overcome this problem by doing-
  • Disable Tablet Mode
  • Unpin and Repin Apps to the Taskbar
  • Reinstall or Update the App
  • Delete the Icon Cache
  • Use the DISM and SFC Tools
I have read of them missing in Windows 11, but not an infrequent disappearance.
I suspect it could be a faulty update.. Have a look and make sure you are up to date - should be build 22000.469.
Alternatively, if the updates are ok, try rolling back to a previous update to see if it eradicates the problem,
