Whats the easiest way to move a spreadsheet of contact info to my iPhone contacts?
harperthomas
I need to share my contacts to my friend, but the problem is my contacts are stored in a excel file and when I export them in my phone the file type doesn't support in my iPhone. That's why I need a prefect as well as easy solution for this. Suggestions Please??
ariana gomez
Turning your list of contacts (usually in Excel format) into a vCard (.vcf) file that your iPhone can read is the best way to move the contacts from the spreadsheet to your iPhone. You need to change the format of the Excel file before you can read it on your iPhone.
To do it, follow these steps:
  • Make sure that your worksheet is well in order. First Name, Last Name, Phone Number, Email, and so on should be written in each box. The information for one person should be in each box.
  • Make the Excel file into a VCF file type. vCard files are easy for iPhones to read. You will need a software that can migrate Excel files (.xlsx or.xls) to vCard files (.vcf) in order to complete the conversion of these files.
  • Move the vCard to your iPhone. Once you're done, you can email yourself the.vcf file, open the email on your iPhone, tap the file, and choose Add All Contacts. Everything will be added immediately to your iPhone.
This method is faster when you have a lot of names in your list because you don't have to add each one by manual.
To make the conversion process easier, you can use a tool like WholeClear Excel to vCard Converter. That tool swiftly converts your Excel sheet into a vCard file that works great on your iPhone. It's simple and easy to use. This can be especially helpful if you're not good with technology and just want a simple solution without a lot of steps. It can smoothly run on all Windows versions like Windows 11, 10, 8.1, 8, 7, Vista, XP, and other previous versions. Before upgrading to the licensed version you can try its free trial to test it out without any issues.
You save time and avoid making mistakes when you use this tool. It makes the whole process easy and stress-free.
julianhawkins
A vCard (.vcf) file is the best way to get contacts from a spreadsheet to your iPhone. iPhones can easily read vCard files and add the contacts to your list. One simple tool you can try is called DataVare Excel to vCard Converter. You don't have to do any hard steps to get your Excel file into the right format. This tool lets you map the fields in a worksheet, like which column has the phone number. It's quick, easy for beginners to use, and saves a lot of time. This software can simple to operate on all Windows versions and also supports all Excel file editions. You can give it a try by using its demo versions for free.
SHUT UP SPAMMER
johndavis379
I recently had a similar problem and learned a really easy way to resolve it. I wanted to put all of my contact information from a list on my Phone so I wouldn't have to type it all in. A specific tool that helped me perform well was Softaken Excel to vCard Converter. It takes your Excel file and changes it into a vCard (.vcf) file, which is how iPhones and other applications store contacts. After making the vCard, I sent it to myself via email, opened it on my Phone, and added the contacts right away.
I attached a video guide for you, hope its helpful
