Win 21H2 still has not updated
Dirtnapper
I was waiting for the 22H2 update, almost end of year and still not updated, any ideas? Thanks.
Edition Windows 11 Home
Version 21H2
Installed on ‎4/‎28/‎2022
OS build 22000.1281
Experience Windows Feature Experience Pack 1000.22000.1281.0
Version 21H2
OS build 22000.1281
Does your system meet the requirements for the update? You can check the website below for the requirements to upgrade.
I suggest reading the entire article!
Version 21H2
OS build 22000.1281
Experience Windows Feature Experience Pack 1000.22000.1281.0​
it seems to be some users still have not obtained the 22H2 as well, I personally upgraded to 22H2 via original Microsoft ISO (available in their website) ..
if you tend to upgrade manually, it's still possible ..
Upgrade to Windows 11 22H2 from Installation Assistant
You can also use the Installation Assistant to upgrade from Windows 10 or 11 21H2 to Windows 11 22H2. To upgrade to Windows 11 22H2 with the Installation Assistant tool, use these steps:
  1. Under the “Windows 11 Installation Assistant” section, click the Download Now button.​
  2. Double-click the Windows11InstallationAssistant.exe file to launch the tool.​
  3. Click the “Accept and install” button to begin the upgrade to Windows 11 22H2.​
Windows 11 Update Assistant
After you complete the steps, the setup will continue upgrading the computer to the latest operating system release.
Option 2 ..
Upgrade to Windows 11 22H2 from ISO file​
To upgrade to Windows 11 22H2 from Windows 11 21H2 or Windows 10 with an ISO file, use these steps:
  1. Open Microsoft Support website.
  2. Under the “Download Windows 11 Disk Image (ISO)” section, select the Windows 11 option.
  3. Click the Download button.
  4. Select the installation language.
  5. Click the Confirm button.
  6. Click the Download button to save the Windows 11 22H2 ISO file.
  7. Right-click the ISO file and select the Mount option.
  8. Click on the mounted drive from the left navigation pane.
  9. Double-click the Setup file to begin the Windows 11 22H2 upgrade process.
  10. (Optional) Click the “Change how Windows Setup downloads updates” option.
  11. Select the “Not right now” option.
  12. Click the Next button.
  13. Click the Accept button to agree to the terms.
  14. Click the Install button to upgrade to version 22H2 while keeping your files and apps.
Once you complete the steps, the upgrade process to the Windows 11 2022 Update will start, and your previous settings, apps, and files will migrate automatically.
Dirtnapper
Thanks worked fine after I did the health check!
