Windows Daily
- Jul 5, 2024
Windows Daily submitted a new resource:
Windows 11 Keeps Crashing? Ultimate Guide to Fix It - Corrupt or broken system files are the chief causes of this issue.
Read more about this resource...
Experiencing frequent crashes on Windows 11 can be frustrating. This guide will help you troubleshoot and resolve the issue effectively.
What Can I Do If Windows 11 Keeps Crashing?
1. Check for Updates
- Open Settings: Click on the Start Menu and select the gear icon to open Settings.
- Go to Update & Security: Navigate to this option within the Settings menu.
- Tap on Windows Update: You'll find this in the sidebar...
