I didn't comment on performance but I don't see any difference with Windows 11 vs. 10. It's not faster or slower, it's exactly the same. I think speed of computers performing program execution is controlled by your processor's speed and maybe room on your drives.Should i upgrade to windows 11? I bought a new laptop and able to upgrade from windows 10 or should i stay with 10? I have an acer laptop. Hows the performance with 11?
"Worth" Tough wording of your question. It would probably depend on whether you are an enthusiastic, or game player user.Should i upgrade to windows 11? I bought a new laptop and able to upgrade from windows 10 or should i stay with 10? I have an acer laptop. Hows the performance with 11?
Thank you for your reply and I am relieved to know that the new Media player app will rip and burn Cds. I read that trying to download Spotify in Windows 11 will involve a little adjustments (I think there are three tests that can be used) one of them is to disconnect entirely ones computer from the internet and then connect again if download does not work then to progress to test2 and if no joy progress to test3. I suppose with new Windows11 it should improve things but from two users of Windows11 I get opposite views that's why I am being a little cautious as to whether to get Windows11...Groove is still on Windows Eleven on my computer. MPC-HC is version 10.0.22000. It says it was updated Dec. 14, 2021. I've never used Spotify, but I see no reason that any program that ran under Windows 10 won't also work on Win 11.
