XM Registry & Other Tweaks v1
List Of Useful Windows Registry Tweaking Tools (Restart Required After Installation Registry)
Add Compact OS Context Menu.reg
Add Component Store Clean Context Menu.reg
Add Co-Pilot Button Taskbar.reg
Add Copy - Move To Folder To Context Menu.reg
Add E Drive Bottom of Navigation Pane of File Explorer.reg
Add E Drive Top of Navigation Pane of File Explorer.reg
Add Reset Permissions Context Menu.reg
Add Run As Administrator Context.reg
Add Spotlight Icon To Desktop.reg
Add User Folder Explorer.reg
Administrators UAC Elevate Without Prompting.reg
Always Enable Local Security Authority Protection With UEFI Lock.reg
Always Enable Local Security Authority Protection Without UEFI Lock.reg
Change Insider Settings to Beta Channel.reg
Change Insider Settings to Canary Channel.reg
Change Insider Settings to Dev Channel.reg
Change Insider Settings to Release Preview Channel.reg
Classic Windows Explorer Style.reg
Default Moden File Explorer With Command Bar.reg
Default User Choice Local Security Authority Protection.reg
Disable All Advertisement & Tailored Experiences.reg
Disable Apply Default Account Picture.reg
Disable Auto Discard Sleeping Tabs - Microsoft Edge.reg
Disable Local Security Authority Protection.reg
Disable Lock Screen Changing.reg
Disable OPEN FILE SECURITY WARNING.reg
Disable Peek For Current User.reg
Disable Quick Access Menu.reg
Disable Show More Option.reg
Enable Apply Default Account Picture.reg
Enable Auto Discard Sleeping Tabs - Microsoft Edge.reg
Enable Co-Pilot Button Taskbar.reg
Enable Lock Screen Changing.reg
Faster Explorer.reg
Folder Fixer - Rename.reg
Force Allow Applications Access Generative AI for ALL Users.reg
Permanently Delete - Context Menu.reg
Remove All User Folders.reg
Remove Compact OS Context Menu.reg
Remove E Drive Botton of Navigation Pane of File Explorer.reg
Remove Managed By Your Organization - EDGE.reg
Remove Spotlight Icon To Desktop.reg
Restore Default System Font.reg
Show Firewall Network Protection.reg
Show Ransomware System Security.reg
Show Virus Threat Protection.reg
Take Ownership.reg
Turn OFF Local Security Authority Protection.reg
Turn OFF Microsoft Defender SmartScreen - Edge.reg
Turn On END TASK.reg
Turn ON Generative AI Access for All Users.reg
Turn ON Generative AI Access for Current User.reg
Turn ON Local Security Authority Protection.reg
Turn ON Microsoft Defender SmartScreen - Edge.reg
Turn ON Seconds Taskbar Clock.reg
Some Useful Command Prompt Tweaking Tool (Batch Files)
Rebuild Icon Cache.bat
Offline Insider Enrollment.cmd
Remove Managed By Organisation - Registry.bat
Replace Below Files In C:\Windows\System32\Drivers\etc
protocol
networks
services
hosts
lmhosts.sam
DNS.txt - Custom DNS Listing
Windows Defender Remover.exe - Windows Defender Disabler / Remover (USE WITH CARE!)
Microsoft Program Install - Uninstall.diagcab - Microsoft Application Install & Uninstall Tool
WU Show & Hide Updates.diagcab - Microsoft Windows Update Hider
Download -
