How can i resize default window on Snipping tool?
The old Snipping tool had a nice, small window but the new one doesn't. This is causing issues for me when taking screenshots because i usually have multiple live streams open, sometimes 16-20, and the current window covers most of them. Is there any way to resize the default window? Thank you!
If I want just part of a window that has the focus I either press the PrntScrn key, open the Snipping tool [in All apps] or press Windows Key + Shift + S to get the choice of selecting an area when then copies to the Clipboard and usually also saves in Pictures\Screenshots. What is wanted to be clipped has to be in focus, in front of other windows. Or one can get the whole screen.
Examples:
Only way I've found is to make the change each time is to click the floppy disk icon upper right and make a choice for Save as.
