Annoying popup when clicking images when searching
Eleven_User
Open a chromium browser and perform a search for anything, then click the wording "Images" (not Google chrome itself) when searching we now see this popup that's forcing us to select either Google or Bing. Is there some way to disable this permanently. I do know that this popup doesn't work on Vivaldi yet does on Brave, both chromium browsers.
I hate Edge as much as dislike Google as a browser as they monitor what ever one is searching for; not that I am doing anything illegal, so I want it gone.
Any ideas how this can be achieved?
Eleven_User
It does in Brave, not in Edge, and don't use Chrome, Firefox Developer doesn't, tends to be other chromium browsers.
Then we shall need the one use Brave to answer, I will try download browser and experiment a little bit on your question later on .. I am satisfied with Edge since it seems a better internet browser (IMHO) ..
Maybe you can try removing these? I never get any popups susch as your screenshot ..
Eleven_User
I did remove just Google and Bing and it made no difference, will try removing all bar Brave and report back.
