Ian
- Jun 8, 2021
Ian submitted a new resource:
How to Uninstall OneDrive - Tutorial on how to fully uninstall OneDrive from Windows 11
Read more about this resource...
We previously posted how to disable OneDrive on your system, however if you'd like to uninstall it fully you can do so via the Control Panel. This means that your synchronised files will be removed from your system and you will have to re-install OneDrive for it to work again. Any existing files will remain in the OneDrive cloud, but they may be removed from your local system and will no longer...
