- Jan 22, 2023
I'm sure I'm not the only one, who has experienced the failure of an external HD. I've been given several such failed devices, and even had one or two of my own. In fact I had one this past week. I've never bought an external HD, so I'm assuming that someone must have given it to me... A very small and compact, USB, 1TB backup drive. I've used it for some time, to hold data backups from my computer that I'm on now. Last time I wanted to use it, my PC would make weird sounds when I'd plug the drive into any of my USB ports, but it would not read the drive. So, calling on my experience with such devices, I cracked open the case, and removed the 1TB Toshiba HD (spinner, not SSD)
I slaved the little (laptop) drive to my main desktop PC and ran a drive check. It checked out 100% good.
So now that reclaimed drive is permanently mounted inside this very PC, as my 'Backup' drive.
I wonder just how many external HD's are just thrown away every year, because they stopped working.
Several years ago, I was given a WD 8TB external drive, that only worked for a short time and then quit.
Suspecting that the problem was in the interface and not the drive itself, I set about getting the full sized Seagate drive out of the enclosure.
It wasn't easy! I thought I'd have to use the "Jaws of Life", because the case seemed to be sealed. But with a screwdriver, hammer and lots of persistence, I finally got that drive out of that case, totally destroying the case in the process.
But once out of the case, and under test, the drive itself proved to be AOK! It now resides in my Main PC, as a storage drive. Waste not, want not!
As an extra Storage drive, it has to be one partition and formatted NTFS. For large files, like ISO's, and backup image files, it works great.
Shadow
Shadow
